Lisp modification (inserting images)
BB8x
Message 1 of 10
BB8x
Hi all
I am using 2 attached lisps. They insert multiple images into Autocad as a ref files. Attached files have random names. Is a chance to modify this lisps to insert images with their real name files?
Replies (9)
Message 2 of 10
ronjonp
Give this a try:
(defun c:img (/ ang dis ins lst spc o)
  (if (and (setq lst (lm:getfiles "Select Image Files to Insert" img:dir nil))
	   (setq ins (getpoint "\nSpecify insertion point: "))
    (progn (initget 4)
	   (setq dis	 (cond ((getdist "\nSpecify image spacing <0>: "))
			       (0.0)
		 spc	 (vlax-get-property
			   (vla-get-activedocument (vlax-get-acad-object))
			   (if (= 1 (getvar 'cvport))
			     'paperspace
			     'modelspace
		 ang	 (angle '(0.0 0.0 0.0) (trans (getvar 'ucsxdir) 0 1))
		 img:dir (vl-filename-directory (car lst))
	   (foreach img	lst
	     (setq
	       ins (cons (+ (car ins)
			    dis
			    (vla-get-imagewidth (setq o (vlax-invoke spc 'addraster img ins 1.0 ang)))
			 (cdr ins)
	     ;; RJP - name of image to match filename
	     (vla-put-name o (vl-filename-base img))
  (princ)
(vl-load-com)
(princ)
Message 3 of 10
BB8x
Thanks mate for reply, but result is still the same
Message 4 of 10
ronjonp
@BB8x  Strange .. works here:
Message 5 of 10
BB8x
I tried many times from many directories same result. Does work. Mine is Autocad 2017
Message 6 of 10
BB8x
Edit: does not work
Message 7 of 10
ronjonp
Not sure what to say .. but I'm also running 2022.
Message 8 of 10
BB8x
Now I do not know what to say. After few days I tried again and it works. Have a feeling autocad needed computer reboot.
Thank you for this ronjonp
Message 9 of 10
ronjonp
Glad to help 🍻
Message 10 of 10
BB8x
Bit odd. Usually works great, but from time to time works in old style with funny names. After autocad reboot proper names are in place
