Creating a TIFF
Creating a TIFF
DartGTDan-2018
Creating a TIFF
DartGTDan-2018
I have a 2018 drawing that the requesting engineer would like output in TIFF format.  I tried the TIFOUT command, but the image is very pixelated/muddy looking, not legible at all.  I usually provide PDF files, which are extremely legible, but this engineer insists on TIFF.  Any suggestions?  TIA
Pointdump
BlueBeam will convert a PDF to Tiff. There might be others.
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
JRitner
If you have Adobe Acrobat you can save the PDF as a TIFF image.
Joel Ritner
C3D Certified Professional
BIM/Systems Manager
Najarian Associates, NJ
fatal.error
You can add a TIFF virtual printer with additional settings control.
No third-party software needed. Please follow these steps:
1. Open the Plotter Manager: type PLOTTERMANAGER on the command line or go to Main Menu >Print > Manage Plotters
2. Double click on Add-A-Plotter Wizard.
3. Click Next, select My Computer and click Next again.
On the Manufacturers column select Raster File Formats. On the Models column select TIFF Version 6 (Uncompressed).
4. Click Next 3 times, edit the Plotter Name as desired and click Next again.
5. Open the file to be exported, type PLOT and select the newly created printer. Make sure Quality is set to Maximum and choose/create a high resolution paper size.
6. Furthermore, to enhance color quality, click on the Properties button, expand the Graphics tab, click on Vector Graphics and select 32-bit color depth.
DartGTDan-2018
JRitner,
That seems to be the ticket!  Thank you!
