I have created the 2 data extractions ("A" & "B") which I want linked to 2 separate tables within a drawing - I cannot attach them so willy include screenshots to assist in explanation.
I can link the contents of one (ie. A) into a data extraction table by updating the path of the data extraction within the external references tab.
However, I cannot see a way to introduce a second data extraction external reference to be able to link the contents of the second into a second data extraction table, as indicated below.
Is there a way to achieve this?
Solved by Valentin-WSP. Go to Solution.
I didn't think of ZIPing - see attached.
The error message you received touches on my query - Is there a way of referencing a .dxex file without using the original drawing file?
Sorry, the only way I can think of doing this is by using Data Link followed by the Table command.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
