AutoCAD Forum
Linking a Second Data Extraction (.dxex) External Reference
5 REPLIES 5
Jake_PCH
489 Views, 5 Replies
I have created the 2 data extractions ("A" & "B") which I want linked to 2 separate tables within a drawing - I cannot attach them so willy include screenshots to assist in explanation.
I can link the contents of one (ie. A) into a data extraction table by updating the path of the data extraction within the external references tab.
However, I cannot see a way to introduce a second data extraction external reference to be able to link the contents of the second into a second data extraction table, as indicated below.
Is there a way to achieve this?
5 REPLIES 5
Valentin-WSP
in reply to: Jake_PCH
@Jake_PCH ,
Like to try with your *.dxex files, please ZIP and attach.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Jake_PCH
in reply to: Valentin-WSP
I didn't think of ZIPing - see attached.
Valentin-WSP
@Jake_PCH ,
Also attach your drawing.
Emilio Valentin
Jake_PCH
The error message you received touches on my query - Is there a way of referencing a .dxex file without using the original drawing file?
Valentin-WSP
@Jake_PCH ,
Sorry, the only way I can think of doing this is by using Data Link followed by the Table command.
Emilio Valentin
AutoCAD Inside the Factory
