Link fields to table cells
farzanbayat74
Message 1 of 19
farzanbayat74
Hi
How can I link a field to a table cell content?
Replies (18)
Message 2 of 19
paullimapa
Message 3 of 19
paullimapa
Paul Li
IT Specialist
@The Office
Message 4 of 19
farzanbayat74
Hi @paullimapa , thanks for your response.
I want to have a field outside the table and this field shows the value of table cell.
Message 5 of 19
paullimapa
then you'll need this add-on which is not free:
How to link / insert a table cell to AutoCAD fields. - YouTube
Paul Li
IT Specialist
@The Office
Message 6 of 19
TerryDotson
Assuming your table cell content is numeric:
  1. Initiate the FIELD command.
  2. Field Category: All
  3. Field Names: Formula
  4. Click [Cell] button.
  5. Click [OK] to begin placement.
AutoCAD fields prevent this from working on non-numeric content.  Some might call it a design limitation; some call it a very mature bug.
Message 7 of 19
dbroad
If you're willing to use a LISP command, this might work for you.
;;Basic demonstration of linking a table cell to a field
;;No error checking, no guarantees. Seems to work. Creates a text object.
;;D. C. Broad, Jr.  4/17/2023
(defun c:fieldcell (/ textent textobj oid)
  (if
    (and
      (setq textent (car (nentsel "\nSelect table cell")))
      (setq textobj (vlax-ename->vla-object textent))
      (setq oid (vla-get-objectid textobj))
     (command "_.text"
	      pause
	      (strcat "%<\\AcObjProp Object(%<\\_ObjId "
		      (itoa oid)
		      ">%).TextString>%"
  (princ)
Architect, Registered NC, VA, SC, & GA.
Message 8 of 19
ChicagoLooper
@farzanbayat74 wrote
<<...I want to have a field outside the table and this field shows the value of table cell....>>
Use MTEXT to display the value of the cell.
Start mtext command=>>Right-click=>>Insert Field=>>then do this:
Chicagolooper
Message 9 of 19
TerryDotson
This portion does not appear to work when the cell font is truetype, unless the drawings VisualStyle is set to "Realistic".  Cells using SHX fonts always seem to work.
Found the same problem in the .NET GetEntity, GetNestedEntity.
Message 10 of 19
dbroad
That seems about right with AutoCAD. It's always something.  Just when you think it works right, it doesn't.
Message 11 of 19
dbroad
So some eager beaver could add on by  1)Using hittest to determine which row and column is selected, 2)Get the celltextstyle for that cell, 3)determine whether that style is SHX 4)if so, do fieldcell, 5)otherwise create a temporary text style with an shx font, 6)temporary set the celltextstyle for that cell, 7)do the function fieldcell actions, 8)set the celltextstyle back to whatever it was, 9)delete the temporary text style.
Message 12 of 19
TerryDotson
So some eager beaver could add on by  ....
I had a different train of thought, added an option to our ToolPac Table SubSelection tools so the user can simply swipe across the cells they want to create linked mtext from and click a button.  It instantly creates all the fields in the current layer so the user can then simply drag them to the desired locations.
Could be used in combination with a linked table from Excel, etc.
Message 13 of 19
farzanbayat74
Thanks @TerryDotson , It worked. easy and no need for lisps 👍
Message 14 of 19
olov_backlund
Observer
Observer
Is it possible to get the cell's value without what is before the cell's value?
{\fAptos Narrow|b0|i0|c0;2024-05-29
Would like it to look like this: 2024-05-29
Thanks in advance!
Olov
Message 15 of 19
cadffm
don't use internal Mtext formattings (your sample: Overrided Font for example)
but yes, it is also possible to by a change of your fieldcode:
HTH
Sebastian
Message 16 of 19
olov_backlund
Observer
Observer
Thanks for the help. Is it possible to force the cell value to be in uppercase?
/Olov
Message 17 of 19
cadffm
Sebastian
Message 18 of 19
HuynhMinhTri
Community Visitor
Community Visitor
But it can link cell value to text
Message 19 of 19
olov_backlund
Observer
Observer
It is possible to merge two or more cell values with a space between them?
And is it possible to add these fields to a block?
/Olov
