i am currently working in AutoCAD for the last week or so and i have been having a lot of issues with it being extremely glitch the curser bouncing around when I'm trying to select point then there's the point showing up way off from where they are supposed to be also have issue with the program freezing only way to fix it is to close out and recover file or i found opening task manager and closing the task manager fixes it for a minute then i have issues with thing disappearing when i had save the file closed it and when reopen stuff is gone or moved some where else also have issue with layers not doing what they are supposed to in plotter even had 2 different plots in same files and the layers did 2 different things does any one have any solutions.... i also spent 8 hrs. one day trying to solve this i went threw every GPU CPU video card setting in my laptop to solve this and there was no help even using AIs there wasnt a solution found
