problems with AutoCAD
luke_larose
luke_larose
i am currently working in AutoCAD for the last week or so and i have been having a lot of issues with it being extremely glitch the curser bouncing around when I'm trying to select point then there's the point showing up way off from where they are supposed to be also have issue with the program freezing only way to fix it is to close out and recover file or i found opening task manager and closing the task manager fixes it for a minute then i have issues with thing  disappearing when i had save the file closed it and when reopen stuff is gone or moved some where else also have issue with layers not doing what they are supposed to in plotter even had 2 different plots in same files and the layers did 2 different things does any one have any solutions.... i also spent 8 hrs. one day trying to solve this i went threw every GPU CPU video card setting in my laptop to solve this and there was no help  even using AIs there wasnt a solution found
gbattinPH5TG
This seems to be a common issue lately.
enter GFXDX12 in the commandline then set to zero. close ACAD and open again
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-make-AutoCA...
luke_larose
THANKS I WILL GIVE IT A TRY SEE IF THAT HELPS
BhaskarMurari
These are basic checks for any performance issues, please try one after another and verify if this helps.
- Downgrade to DirectX 11 from DirectX 12 (set the variable GFXDX12 to "0").
- Check the mouse polling rate; it should be around 130 Hz.
- Ensure all monitors connected to the computer have the same resolution and display scale.
- If using a docking station, bypass it and connect the HDMI cable directly to the laptop.
- Install the latest updates for AutoCAD and the operating system.
- Update the graphics driver and ensure hardware acceleration is turned off if necessary.
- Reinstall Visual C++ and .NET Framework.
- Perform a clean reinstall of AutoCAD if the problem persists.
- Use the command `Purge` and `Audit` to clear unwanted layers, blocks, and errors.
- Copy the entire drawing using "Copy with Base Point" and paste it into a new drawing file.
- Ensure the drawing content is close to the origin point (0,0) and use Xrefs for high-coordinate drawings.
- Repair the drawing file using tools like `Purge`, `Audit`, and `Recover`.
- Check for OLE objects and isolate them or place them on a thawed layer.
- Use True Type fonts like Arial or Calibri and avoid bold or italics with SHX fonts.
- Verify system requirements for AutoCAD and ensure all updates are installed.
- Increase available memory (RAM) and page file space.
- Update to the latest certified video driver and ensure DirectX is up-to-date.
luke_larose
I HAVE TRIED ALL THAT. DOWNGRADING THE DIRECTX SEEMS TO HAVE HELPED ALOT.
luke_larose
OK I HAVE DONE ALL THIS AND DOWNGRADED TO DIRECTX11. AND IM STILL HAVING GLITCHING ISSUES. IVE DONE ALL OF THAT PLUS WENT THREW ALL MY CPU AND GPU SETTING RECOMENDED BY AI TO SOLVE THE ISSUE. AND NOTHING HELPS  I OPEN A FILE AND IT SEEMS GOO FOR LIKE 2 MINS THEN STARTS GLITCHING.
BhaskarMurari
@luke_larose Can you share the drawings using ETransmit  so that I can check
