LINEWEIGHT NOT SHOWING IN LAYOUT SPACE
Message 1 of 11
Hi Everyone,
I'm having real issues trying to get my lineweights to show up in the Layout Space.
I've seen loads of posts on here asking the same question, I've tried all the solutions on here correctly (I think), but nothing seems to have worked.
I'm not hugely experienced with AutoCAD but have been using for around a year and haven't had this problem before!
If anyone could offer some advice I would hugely appreciate it!
TIA
Replies (10)
Message 2 of 11
natasha.l
Hello @Anonymous,
Please verify the proper layer specs.
Make sure the "Plot" display is not disabled on your layer in the "Layer Properties Manager" dialog box.
Make sure you have "Plot Object Lineweights" checked.
Please share the file if you continue to have an issue. Thank you.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 11
beyoungjr
PSLTSCALE off, then REGEN.  Might need to do that with the Viewport active.
Blaine Young
Senior Engineering Technician, US Army
Message 4 of 11
s.borello
Post a sample file and a speedy resolution will follow.
Message 5 of 11
user181
Hi @Anonymous    If you want to see the lineweights on the screen then set LWDISPLAY to ON
Message 6 of 11
beyoungjr
Oh Oops!  Lineweight not Linetype Scale... Sorry for my confusion.
Blaine Young
Message 7 of 11
Thank you for advice Natasha!
I've just tried everything you've suggested and everything seems to be correct. The first image you posted of the layer properties, mine looks really quite different to yours, I don't have any plot option in there for example? Just so you know I'm using the MAC 2018 version.
The lineweights are showing up in the Model space, but not showing in Layout 1. I've made the lines really thick in the model space just in case it was the scale that wasn't set up right in the layout space, but that hasn't seemed to work either! Really frustrating. I am still learning AutoCad though so it could just be my lack of knowledge.
I will attach the file here, please note the lines look very thick at the moment, they won't be this thick once the issue is sorted.
Thank you again your help is hugely appreciated!
Message 8 of 11
Hi! Thank you for replying.
Yeah I've tried this and it's still not working 😞
Message 9 of 11
jayhar
Hi @Anonymous
you wrote
<<<<<<I'm having real issues trying to get my lineweights to show up in the Layout Space>>>>>>
Please Upload AutoCAD 2013 format
Are you working in inches or in millimeters?????
Zoom up layout space lineweights will show up, Before check marked Display Lineweight (LW)
In Plot Style Table Editor > Edit > Lineweight > you can specify the numerical value of each Lineweight
plot options on the left check to see if 'Plot object lineweights' is selected
CELWEIGHT <-1>
LWDISPLAY <ON>
Some helpful links
Display Lineweights Link & AutoCAD lineweights Link
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 10 of 11
Alfred.NESWADBA
First please try these steps:
  • Activate Layout 1
  • make sure you are in paperspace
  • zoom close to the upper right border of your paper, so you see the first 3 to 4 lines of your legend.
  • now turn on and off LWDISPLAY ... do you see a difference or not?
That is what I see when switching the LWDISPLAY parameter (left is ON, right is OFF😞
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 11 of 11
nadiah-x_zelani
Community Visitor
Community Visitor
i encounter the same too. so basically what i did is do a new viewport and Line weight appeared like how it should be.
didnt find any solution with regards to all the setting above setup correctly.
