AutoCAD won't plot inside the frame that I have specified
2024_11036
2024_11036
I've been trying to plot my house plans from .dwg to .pdf on an A3 format in 1:50 proportions (so that for example 19cm will appear 50 times smaller on an A3 paper). The problem is AutoCAD doesn't plot the contents of the window properly, it keeps adding these margins that deform the proportions. I've highlighted the corners that I want to be the corners on an A3 paper in the attachment below, not just random ones on the paper. I've also attached the settings that I use that should work in normal circumstances. Any help would be appreciated!
paullimapa
If you don't want margins then use Full Bleed paper size:
Paul Li
IT Specialist
@The Office
2024_11036
This looks much better, thank you!
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
