Several things to check:
Are the lineweight properties of the lines in question set to ByLayer, or have they been manually changed?
Are the lines in question Polylines that have a defined width greater than 0?
Does the ctb file you are using assign lineweights by color, or are they left at the default of Use Object Lineweight?
Once you check these and correct as needed, plot several pages to pdf or paper (however you plan to release them) and see if the result is what you want (sometimes the Preview can be misleading) then edit lineweight settings as needed.
Hope this helps.
additional questions to the ones from @Anonymous :
- alfred -
What @Anonymous said.
To phrase a different way:
1. Polylines with an non-zero "width" property will plot that width, regardless of anything else.
2. Objects that are not affected by a plot style (i.e.: they have a true color or colorbook color, or there is no plot style assigned to layout) will be printed as defined by their lineweight.
What does that have to do with this issue?
Both depends on scale, but in the layout you have 2 scales, one is the viewport scale and a second one in the plot dialog (which can create postage stamps sized output instead of the real paper format and then lines with 0.05mm really look thick)
- alfred -
thanks for the reply, the lines are set by layers, none of them are polylines, and what do you mean by cbt files aligning them by colour? sorry, im new to autocad
hello!, im plotting from layout, at the moment its on default and they look thick, which is 0.25mm, im working with autocad 2020, ive attached the pdf below
can you please upload the DWG-file too?
- alfred -
i use the straight lines for everything in my drawings so would it be an issue? sorry im so new to it all im learning as i go
looking to your PDF ... what's wrong with that?
That's what I see:
- alfred -
it just looked so thick on the pdf that i thought it would print that way? has it been fine all this time! so sorry
your drawing is really not the best sample for structured dwg.
All you objects are on layer "0", that's not how it's supposed to work.
Anyway, your PDF is ok, I don't see issues inside your PDF.
- alfred -
I can't agree with "it looked so thick", I see that as a normal lineweight.
Best you can do to prove that: Print it, and you'll see how it will look like on the paper.
- alfred -
>> is this one better?
Well, you have created one layer "floor plan", but you have objects like wall, door, window, floor, I guess furniture, tv, ... I would have them on different layers, just to be able to plot in different ways (one time wall, door, window only, one time with furniture, ...)
The trainer of your class should be able to teach you in layer structures, it's one of the important things in CAD.
- alfred -
okay well noted, i do usually i just assumed when saving it if i want it all printed it wouldn't matter, i thought layers were mainly for freezing things. What do you mean by "to be able to plot in different ways"?
As I wrote (just as samples):
- alfred -
