Lineweight display in paper space
open this link → About Lineweights | AutoCAD 2020 | Autodesk Knowledge Network
it says : lineweight display in paper space change with the zoom factor.
But when I zoom in paper space lineweight does not change. why ?
one is without zoom and other is zoomed however both lineweight appears same
Valentin_CAD
@Anonymous ,
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Kent1Cooper
That is because the object in question is in Model Space, seen through a Paper Space Viewport -- it is not in Paper Space.  Try drawing something actually out in Paper Space, give it a discernible lineweight, and Zoom in and out to see the difference.
Kent Cooper, AIA
user181
If you have the viewport active and unlocked you probably won't see a lineweight difference.  If you lock the viewport or use the pspace command to get in paperspace and then zoom in and out you should see a difference.
In observation I see,
                                  Zoom
unlock,outside→     yes
Lock,outside→         yes
unlock,inside→        no
lock, inside→           yes
