AutoCAD Forum
lines of different colours printing over each other
4 REPLIES 4
Theolopodis66
322 Views, 4 Replies
Hi, please could someone help me?
i have printed to PDf, but the light grey lines i'm using for easthetics, are printing over the black boundary lines.
is it possible to make the black lines overwrite the grey?
thanks for any help
theo
4 REPLIES 4
WeTanks
in reply to: Theolopodis66
can you share the file?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
imadHabash
  • Try from your plotter( PDF options ) to check Merge control option .
  • You can also use that hatch as a black color but with increasing transparency value .. this way you won't notice the problem.
Imad Habash
TomBeauford
In the drawing just use the DRAWORDER command from the Modify tab after either selecting the black lines to Bring to Front or selecting the light grey lines to Send to Back.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
3wood
There is a CDORDER command in the Express Tools which sorts out object draw orders by color.
AutoCAD Inside the Factory
