AutoCAD Forum
line type definition
5 REPLIES 5
1448 Views, 5 Replies
How do I get the definition or code of a line type that is loaded in a .dwg? I have a lisp that loads layers and line types, but the routine stops in a new drawing, because the DEMO line type is not in the acad.lin file.
5 REPLIES 5
pendean
Post your LISP file, lets see what it is actually trying to do.
Kent1Cooper
Put something like "extract linetype definition" or similar wording into the "Search the Community" window, and you'll find several threads on the subject, with links to routines that do that.
Kent Cooper, AIA
Thanks Kent1Cooper, I found “linout.vlx” and used (load " linout.vlx ") to load it and “linout” to execute the routine and it worked perfectly to what I needed which was to find - *DEMO,DEMO ---- / ---- / ---- / ----
A,0.125,-0.02,["/",Standard,s=0.1,r=0,x=-0.05,y=-0.05],-0.015
john.vellek
Hi @Anonymous,
How about something like this
(setq lstyleinfo (tblsearch "Ltype" "dashed"))
(if (= lstyleinfo nil)(command "linetype" "load" "dashed" "acad.lin" ""))
John Vellek
The AutoCAD Forum won’t let me attach the file - linout.vlx, so if someone needs the file just save it and change the extention to .vlx or you can get it here - https://www.cadstudio.cz/en/download.asp?file=LinOut
