Line thickness display issues
florent_bianco
Observer Observer
Message 1 of 8
florent_bianco
Observer
Observer
Hello, I am part of the IT department of an university in France. Autocad software was installed on educational machines. OS : Windows 10, PC model: https://www.hp.com/fr-fr/shop/product.aspx?id=5v9s4ea&opt=abf&sel=dtp
only, we are experiencing a display problem on these PCs. Indeed, as soon as we request a display with line thickness, the lines whose thickness is greater than 0.3mm disappear. Can you help us ? Thanks
Replies (7)
Message 2 of 8
cadffm
1. Graphic issue
2. Your AutoCAD is not up2date, right?
Install the latest update - 2023.1.4 or 2024.1
Sebastian
Message 3 of 8
cadffm
You can check the productname and productversion by dialog, command: ABOUT
Sebastian
Message 4 of 8
florent_bianco
Observer
Observer
Hi and first, thanks for your reply,
The product version is U.71.0.0
Autocad Version : Autocad 2024.0.1
Message 5 of 8
cadffm
..so update your program
If that doesn't help,
then you have to choose another measure
change the 2D-Display Mode to another one, for example: Basic
Command: GRAPHICSCONFIG
or disable DX12 support
Command: GFXDX12 0
Sebastian
Message 6 of 8
Valentin_CAD
@florent_bianco ,
As @cadffm mentioned, update to 2024.1 Update.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 7 of 8
pendean
Community Legend
Community Legend
Install the 2024.1 Update, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD..
Also consider turning off LINESMOOTHING and LINEFADING variables.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort.
Message 8 of 8
florent_bianco
Observer
Observer
Thanks to both of you guys
It worked with 2024.1 update, issue solved.
Thanks again
