line style
line style
karen_tavener
Message 1 of 15
line style
karen_tavener
why is my linestyle not visable on my screen, but when I print the drawing they are present?
Replies (14)
Message 2 of 15
tramber
You need to use the REGEN command from time to time.
The shortcut may be RG in English.
Message 3 of 15
Kent1Cooper
@tramber wrote:
.... The shortcut may be RG in English.
[The default shortcut/alias for REGEN in the English version is RE.]
Kent Cooper, AIA
Message 4 of 15
karen_tavener
no unfortunately that does not resolve, I still cannot visually see the line styles on screen everything looks solid. I am baffled as to why
Message 5 of 15
karen_tavener
no unfortunately that does not solve issue, still everything appears solid on screen
Message 6 of 15
cadffm
Model or Layout ?
Share your DWG, show us a screenshot of the whole program window and your plot setting.
I know just two situations, but why guessing if you have all the data we can see the problem..
If model, check your MSLTSCALE
Sebastian
Message 7 of 15
karen_tavener
Paper space & Model space both show all line styles SOLID
I CHECKED SCALE IN MODEL SPACE IT IS SET AT '1'
THIS IS SCREEN SHOW FROM PAPER SPACE
Message 8 of 15
Valentin_CAD
@karen_tavener ,
Provide a drawing or look into these links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 9 of 15
pendean
Community Legend
Community Legend
@karen_tavener Share your problem DWG file here please, nothing to hide since you just shared all the client and project info in your screenshots already 🙂
Message 10 of 15
pendean
Community Legend
Community Legend
Message 11 of 15
karen_tavener
Message 12 of 15
karen_tavener
Message 13 of 15
cadffm
@cadffm wrote:
Model or Layout ?
You're welcome
Sebastian
Message 14 of 15
karen_tavener
LAYOUT ON SCREEN SHOWS ALL LINES SOLID UT WHEN I PRINT THEY ARE AS PER LINE STYLES
Message 15 of 15
cadffm
Layout: Are you printing with plot scale 1:1 (in PLOT dialog) ?
Are you plotting with Plotstyletable (but in your Pagesetup, the option "Display plotstyle" is disabled)?
As you can read above, there are some peaople who like to explain it,
but until now, you don't share the data.
There may also be a graphics problem, but we won't know until we can check the DWG.
Sebastian
