AutoCAD Forum
Line/rectangle and other tools don't work unless I specify first point
3 REPLIES 3
803 Views, 3 Replies
Something happened to one of my documents. I am not able to draw line/rectangle or copy (cmnd +c, cmnd +v) in model space without specifying a first point (i.e. putting a value in the field). When I opened a clean new document, these operations worked fine, but not in the document I am working on now. Could anyone help me to solve this? Thanks a lot!
3 REPLIES 3
jayhar
1. Check Current Layer
2. Turn Off Snap On F9, Set Grid X Space, Grid Y Space Line As 1
3. Restart Autocad
Please Upload Your Cad File In 2013 Format
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Vinayv4v
Check if limits is turned on your particular drawing.
Enter command LIMITS > OFF and give it a try.
Cheers,
Vinay Vijayakumaran
in reply to: Vinayv4v
Thank you very much! I switched LIMITS "OFF", and everything works now.
Forma Design Contest
AutoCAD Beta
