Line Not Accepting First Point
適用対象外
I'm doing a project for school and here are the starting directions:
"The point of beginning (POB) of this survey is measured
from BM#8332. This benchmark is located at the northeast
corner of the intersection of SW Washington Street and
SW Oleson Road. The coordinates for the benchmark are
1421334.93,783207.62. The first point in the survey for
Oleson Village (the POB) is 113.66 feet from the benchmark
and at a bearing of N5‹2723W. Note the general location of
these points in Figure 2."
So here's my issue. I'm trying to draw a line from the benchmark of "1421334.93,783207.62", but the line won't stick to that first point. If I start a line at 1,1, it will stick. If I start a line at 1000,1000, it will stick. Even if I knock off the last digit of each number before the decimal point "142133.93,78320.62", it will stick. Why is this? My limits are set to 2000000,2000000. I'm lost. This is scary becasue I havn't even started the project yet and I've spent 2 hours trying to figure this out. Any help would be much appreciated!
Thanks in advance.
PS. I attached the project.
R,
James
0 件のいいね
返信
1,101件の閲覧回数
5件の返信
返信 (5)
適用対象外
Ok, I figured out I can zoom all and now I can see where's the line is attached. Then I put the next point in but it won't attach the line. Here is what I put @Anonymous.66'<n5d27'23"w
Any thoughts?
0 件のいいね
Pointdump
James,
Can you post your drawing, or a screenshot of your Units?
undefined
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
0 件のいいね
適用対象外
Hi Pointdump,
I was able to figure it out.
Thank you.
R,
James
0 件のいいね
Pointdump
James,
Happy to hear you figured it out, but I'd really like to know what you discovered. Please share, and then you can mark your post as the "Solution".
Dave
Dave Stoll
Las Vegas, Nevada
0 件のいいね
適用対象外
I'm on doing this project as well, and I am having the same problems. So if you can text the "solution" that would be awesome. Thank you .
0 件のいいね
製品名を入力してください
