Xref Attach Default Location
carminatithekid1
carminatithekid1
I am wanting to change the default location that is opened when I select "Attach Xref". Can this location be changed?
Randy Carminati
razkaman
i don't know about default, but usually xref  dwg reference always go to the last file that you selected
imadHabash
REMEMBERFOLDERS system variable controls the default path displayed in standard file selection dialog boxes. the initial value is ( 1 ) which mean that the default path in each standard file selection dialog box is the last path used in that dialog box.
i hope it's help..
Imad Habash
