I am entering a line measurement but it is not setting line to entered measurement. Whatever measurement I enter it still allows me to extend line etc. I tutorial video I am using instructor is entering a line Measurement and it is drawing line to that dimension but it won’t on mine! I have tried changing units to Engineering etc but still no joy. Can anyone help please?
Solved by GrantsPirate. Go to Solution.
can we have a screenshot for your issue while LINE command is active ?
Imad Habash
Can you give more details?
You start the LINE command.
Pick a starting point.
Drag the cursor out and then enter a number and then what?
Can you grab a screenshot of the command line during this action?
There is no image attached. Thanks.
@Anonymous wrote:
.... I have sent a picture of my screen. ....
Still no picture. If you are replying to an e-mailed notice on a cell phone, that would be the reason. You need to be on a "real" computer and on the website in a browser.
@Kent1Cooper - I've always heard that too, and I have seen mobile users say the same, but I just tested it and it worked just fine.
See: https://forums.autodesk.com/t5/public-test-forum/this-is-only-a-test/m-p/9494149#M4797
I wonder why it works in some cases and not in others?
@Anonymous - no.
Here is what your post looks like:
Sounds like you are looking for Parametric dimensioning.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
I tried attaching a video but doesn't look like it worked. I will try again in a bit.
GrantsPirate
Parametric dimensioning video...
GrantsPirate
