Line Endpoint Coincident To Perpendicular Line
Carson_Greener
Carson_Greener
How do you do all, I have a box made up of four lines. Inside of this box, I would like to have multiple horizontal lines that will resize with the box length wise. Normally, in Inventor, I would put a coincident constraint on the horizontal lines' endpoints to the vertical line. In autoCAD I'm having a problem where it only allows this constraint on endpoints. If I try to do it I receive the error, "Dimensional value or resultant geometry, is inconsistent with existing configuration". However, I can manually resize the line and it will "snap" to being on the vertical line (Green X) but if I try to move the vertical line left or right, the interior line does not follow.
Here it looks like all lines are connected.
Yet when I drag the vertical right line more to the right, the horizontal line does not follow. Yet I can manually extend the horizontal to it.
Giving me what I would normally call a coincident snap, but does not stay.
EDIT: Solved: Constraint endpoint of one line to some point of other line - Autodesk Community - AutoCAD
Works for this
Carson_Greener
Alrighty maybe a better question is this: Is there a way to make AutoCAD's drawing system more similar to Autodesk Inventor? For example, I make a box with five click. In inventor, these lines would automatically be coincident at the endpoints. However in CAD, they are not and I can separate them by default. Any way to make creating a .dwg more like sketching in an .ipt?
See below solved:
pendean
Community Legend
Community Legend
No.
But you can use the CONSTRAINTS AND PARAMETRIC TOOLS if that is what you really intended to ask
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-899E008D-B422-4DF2-AC8D-1A4F5701ED4E
perhaps even use AutoCADMECHANICAL instead of just plain AutoCAD since that variant is probably closer in alignment to INVENTOR (and is free to install and use if you are a subscriber) https://www.autodesk.com/products/autocad/included-toolsets/autocad-mechanical
Kent1Cooper
... I have a box made up of four lines. Inside of this box, I would like to have multiple horizontal lines that will resize with the box length wise. ....
How about just a Hatch pattern of parallel lines, Associatively tied to the perimeter box?  Use the User-defined option, where you can give it the angle and spacing of the hatch lines directly, and set its origin [I presume] at a corner.
Kent Cooper, AIA
