- Mute
- Permalink
- Report
How do you do all, I have a box made up of four lines. Inside of this box, I would like to have multiple horizontal lines that will resize with the box length wise. Normally, in Inventor, I would put a coincident constraint on the horizontal lines' endpoints to the vertical line. In autoCAD I'm having a problem where it only allows this constraint on endpoints. If I try to do it I receive the error, "Dimensional value or resultant geometry, is inconsistent with existing configuration". However, I can manually resize the line and it will "snap" to being on the vertical line (Green X) but if I try to move the vertical line left or right, the interior line does not follow.
Here it looks like all lines are connected.
Yet when I drag the vertical right line more to the right, the horizontal line does not follow. Yet I can manually extend the horizontal to it.
Giving me what I would normally call a coincident snap, but does not stay.
EDIT: Solved: Constraint endpoint of one line to some point of other line - Autodesk Community - AutoCAD
Works for this
