When typing L for line, it shows the LIST command first. I checked the Alias Editor and there was actually no loaded command list. When I load the acad.pgp file in the Alias Editor and save it, it says its saved but doesn't show up when I reopen the Alias Editor. Thought this was important to mention.
All of my other commands work fine except for the LINE command. In the acad.pgp file the line command is L and the list command is LIST so I don't understand why typing L chooses the list command instead of line.
Does anyone know how to fix this?
it sounds like INPUTSEARCHOPTIONS needs to be turned off.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
I just tried messing with the INPUTSEARCHOPTIONS but it didn't help unfortunately
It would be easier if I can see your workflow. Can you record a screencast of the process you are using?
https://knowledge.autodesk.com/community/screencast
