please,i have a question..
in Multi leader style manager window
there is the setting of leader break / break size ?
can anyone tell me what is this value .. i tried to change it frequent times but nothing happened to the leader ??
i attached the pic below to show its specific place.
thank you
Solved by john.vellek. Go to Solution.
Solved by imadHabash. Go to Solution.
This is for display and set the break size used for the DIMBREAK command when the multileader is selected.
follow this >> Link << for more details.
Good Luck...:)
Hi @Anonymous,
The value you are changing controls the size of the break when using the DIMBREAK command. Is this what you are looking for or are you inquiring about somehting else?
