- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
My issue is this, I have a drawing with multiple layouts, and I want to make VP color overrides in some layers for all layouts.
The problem I have is that to make this, I need to enter the VP and manually make the color override, in my case for a true color, and repeat the process for every single layout, witch is very annoying.
I already tried to match between layouts from the same and different drawings but had no luck.
Why Autocad doesn't have the VP color option in the Model Layer Manager?
Am I missing something?
What I want is to be able to match or apply VP layer color/ properties overrides to all VP.
Is there any solution?
Why do I have the option to "REMOVE VP Layer Overrides for all..." but not the the opposite?
Thanks fot the time taken.
I'm using Autocad 2023.
