Layout Viewport layer color overrides: match properties & overrides (in all viewports drawing).
aflferraz
Message 1 of 29
aflferraz
Hi everyone,
My issue is this, I have a drawing with multiple layouts, and I want to make VP color overrides in some layers for all layouts.
The problem I have is that to make this, I need to enter the VP and manually make the color override, in my case for a true color, and repeat the process for every single layout, witch is very annoying.
I already tried to match between layouts from the same and different drawings but had no luck.
Why Autocad doesn't have the VP color option in the Model Layer Manager?
Am I missing something?
What I want is to be able to match or apply VP layer color/ properties overrides to all VP.
Is there any solution?
Why do I have the option to "REMOVE VP Layer Overrides for all..." but not the the opposite?
Thanks fot the time taken.
I'm using Autocad 2023.
Replies (28)
Message 2 of 29
imadHabash
I think that by layer State Manager you can do something . i suggest to follow this link that may help . >> Click <<
Imad Habash
Message 3 of 29
aflferraz
Hi @imadHabash thanks for the repply,
I already tried that solution, sorry forgot to tell, but anyway tried it again as you suggested and, if I didn't do anything wrong the import Layers state is only applied to the layout layers, not the layout Viewports Layers, and It's also applied to a single layout not all layouts.
Thanks anyway.
Message 4 of 29
RSomppi
Then you don't need VP Overrides. Remove them and assign the desired color.
Message 5 of 29
aflferraz
Hi @RSomppi thanks for the repply,
Can you clarify further what you mean?
Just to be clear, in model I  have a Layer X with color A, and I want to keep that color in model.
I also want same Layer X to have a different color in Vp, and for that I use VP color override.
At this point I have a drawing with multiple layouts and around 80 Viewports without the color overrides.
What I want is to apply that color change but don't want to change the overrides on all Viewports 1 by 1.
Thanks.
Message 6 of 29
RSomppi
Thanks.
It won't work with the further details that you've provided. Not sure why you would want the model space to be a different layer color than every viewport.
Message 7 of 29
aflferraz
@RSomppi  escreveu:
Long story short, in the model space I need to have a diferenet color for layer, that way is more simple to work and check if the element is in the correct layer, but in layout I want a single color to be printed.
Message 8 of 29
pendean
Community Legend
Community Legend
@aflferraz wrote:
...in the model space I need to have a diferenet color for layer...but in layout I want a single color to be printed.
That can only be done as a VPCOLOR layer setting inside viewports in Layouts if you only wish to use core commands and functions.
Message 9 of 29
aflferraz
@pendean  escreveu:
At this point I'm open to any solution, if there's a lisp or something that makes life easier to me is fine.
Thanks for the time taken.
Message 10 of 29
pendean
Community Legend
Community Legend
The LISP forum is over here if you wish to explore that
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Otherwise you seem to know how to do it using only the core functions.
Message 11 of 29
aflferraz
@pendea  escreveu:
Yes, I've been there, either I'm not that good finding a solution for this one or it doesn't exist at all.
Knowing my track record I tend consider the last one, but we should never give up. 😄
Thanks anyway for the time taken
Message 12 of 29
pendean
Community Legend
Community Legend
@aflferraz wrote:
... Yes, I've been there, either I'm not that good finding a solution for this one or it doesn't exist at all...
Why not just post there and ask for help creating a LISP?
You'll want to share your DWG file with many layouts/viewports and explain what how you want the layer name to be chosen.
Message 13 of 29
ВeekeeCZ
Thanks anyway.
You must be active within a particular VP, so it's applied there. I do this all the time, so I know it works.
Save and apply layer state is the way to go!
Message 14 of 29
aflferraz
Hi there,
@ВeekeeCZ  escreveu:
Yes I do know that and that's exactly what I want to avoid.
It works, but only with one VP at time, all solutions lack the option to make it in bulk, for all VP drawing.
If I already have to many VP mounted, I don't want to go one by one to apply de VP color overrides, I want override all the others at once.
Autocad already has the opposite option, "REMOVE VP OVERRIDES FOR ALL/ FOR ONE..." why only remove and not also APPLY.
That's my goal to apply the colors overrides.
Message 15 of 29
RSomppi
It's just the nature of overrides. As has been stated, what you want is not possible without code. Earlier you mentioned that you need this in order the check layer assignments. Without working code, I would explore other workflows so that you can accomplish that review and make make plans for future projects. I suggest Layer Walk, LAYWALK, for your review and moving forward setting up your viewports as you make them in the future so that you can have your overrides in place without having to assign them after the fact.
Message 16 of 29
aflferraz
Yes I did predicted that because I prepared the base drawings with the overrides for someone else, in the future, multiply/ copy the layouts with thoses OV but this time the process went "side ways".
But yes, I think the solution is on a lisp.
Thank for the time taken.
Message 17 of 29
TomBeauford
You're trying to do it the hard way! All you need to do is select the Display Plot Styles option in the Page Setup dialog box of each layout. https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-A5783CCA-CAC8-4C0E-AF8A-928ADA4613A2
There are many lisp routines out there to make doing this even easier like:
; Plot Style toggle
; by: Tim Creary
; http://forums.augi.com/showthread.php?t=75802&highlight=ShowPlotStyles#3
;^C^C^P(or C:ShowPlotStyles (load "ShowPlotStyles.lsp"));ShowPlotStyles
(defun c:ShowPlotStyles (/ acDoc ctab)
  (vl-load-com)
  (setq acDoc (vla-get-activedocument (vlax-get-acad-object))
        ctab (vla-Item (vla-get-layouts acDoc)(getvar "ctab"))
  (vlax-for oLayout (vla-get-layouts acDoc)
	(if (= (vla-get-ShowPlotStyles ctab) :vlax-true)
	  (vla-put-showplotstyles oLayout :vlax-false)
	  (vla-put-showplotstyles oLayout :vlax-true)
  (vla-regen acDoc acAllViewports)
 (princ)
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 18 of 29
aflferraz
Hi TomBeauford,
Sorry but either I miss something or you solution doesn't work.
If I have multiple layers A (in red) and multiple layers B (also in red), all of them will plot in blue with your suggestion that is color base at pen assignment page setup.
That solution will override the color to all layers in red I don't want that.
I want to set that color override for some specific layers, those layers have the original color (red blue, yellow what ever in model) but in viewport they plot in blue.
Autocad has the option to remove that override to all viewports but not the "apply" to all viewports.
Thanks for the reply and time taken,
Message 19 of 29
TomBeauford
What I posted doesn't modify any layer or object colors at all. You asked for a solution to view layouts displaying in the colors they would be when plotted and both the Autodesk link and the code I posted simply display the layouts including viewports using the assigned Plot Styles exactly how they would be plotted like you wanted. Of course you need to have a Plot Style assigned to the layout for it to work.
2023
Message 20 of 29
aflferraz
I'm sorry but as I mentioned in my first post, what I want is to change some layers, if it is for viewing or plotting either way the plot styles won't work because I don't want to change/view/plot all layers (color red in model) to blue when viewport/ plotted to pdf/ dwf whatever.
"My issue is this, I have a drawing with multiple layouts, and I want to make VP color overrides in some layers for all layouts."
In model I may have layers A, B, C in red, but in viewport I just want to view/ plott layer B in blue, the other two not.
