LAYOUT DIM
LAYOUT DIM
LAYOUT DIM
Hi Everybody
I appreciate if you consider my question and let me know how to fix my problem.
According to below picture (attached file as well), dimension in layout is huge in size. I tried either in MODELSPACE (layout) and PAPERSPACE (layout). Non of them go right.
How may I fix it?
Regards
Pedram
l(ayout scale: 1/4" = 1'-0")
Accepted solutions (3)
imadHabash
Hi and Welcome to AutoCAD Forum,
i suggest from DDIM to make your own proper dimension style then set it current and start put your dimensions .
Imad Habash
pendean
Community Legend
Community Legend
You have not set up your dimension style and text style correctly based on your image. If you want more help, post your DWG file, let's see what you have set so far.
Thanks a lot. I did and it worked.
