LAYISO command does not work
Message 1 of 13
Hello Guys,
I am having a lot of troubles with my latest version of ACAD 2017. After purchasing the licensed version and reinstalling my ACAD I tried to type layisolate command in the command line, however it turns back a message "Unknown command". Does somebody had experienced such a problem? I have tried almost anything, please help.
Replies (12)
Message 2 of 13
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
AutoCAD is correct, command LAYISOLATE does not exist 😉
Use command _LAYISO instead.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 13
Hello Alfred,
Please find attached and evidence that _LAYISO does not work also.
Where seems to be the problem then?
Thank you.
Kind Regards,
Peter Zherkov
MSc(Eng), DipStructEng, KIIP
Structural Design Engineer
Barrett Mahony Consulting Engineers
Civil . Structural . Project Management
London . Dublin . Sofia
Sofia:
19 Yakubitsa Street, Lozenets, Sofia 1164, Bulgaria
Tel: +359 (0) 2 494 9772
+359 (0) 2 494 9746
Web:
Email:
www.bmceuk.com
pzherkov@bmcebg.com
p_nav_home>
To view our email disclaimer please click on
http://www.bmceuk.com/disclaimer/
Please consider the environment before printing this e-mail
Message 4 of 13
Alfred.NESWADBA
Sorry, nothing attached.
In case _LAYISO is not working too then I guess your AutoCAD profile is defect or the installation of AutoCAD worked not well.
Just to make sure: you get the same error message with all that icons?
- alfred -
Alfred NESWADBA
Message 5 of 13
Hi again,
The thing is that the program does not associate neither with typint
"LAYISO", nor "_LAYISO".
In the attachment I have taken a snapshot of the screen for evidence.
Kind Regards,
Peter Zherkov
Sofia:
+359 (0) 2 494 9746
Web:
Email:
www.bmceuk.com
pzherkov@bmcebg.com
p_nav_home>
Message 6 of 13
Alfred.NESWADBA
>> program does not associate neither with typint "LAYISO", nor "_LAYISO".
My question was not asking for using "_" or not, my question was: do the other icons from my screenshot also not work?
In case they also don't work:
  • Your AutoCAD profile is defect or the installation of AutoCAD worked not well.
  • Run reset settings to default (>>>click<<<), if that does not work you'll have to repair-install your AutoCAD installation (having admin permission and having antivirus turned off).
- alfred -
Alfred NESWADBA
Message 7 of 13
imadHabash
Would you please try to use REDEFINE command line.
Command: REDEFINE
Enter command name:layiso
Imad Habash
Message 8 of 13
Hi IMADABASH,
That doesn't work, but thank you. I have an additional plugin CADSRC. I
think that it is making any unknown for me changes that seem to be
problematic for the LAYISO command in ACAD 2017.
Kind Regards,
Peter Zherkov
Sofia:
+359 (0) 2 494 9746
Web:
Email:
www.bmceuk.com
pzherkov@bmcebg.com
p_nav_home>
Message 9 of 13
Kent1Cooper
@Anonymous wrote:
.... I tried to type layisolate command in the command line, however it turns back a message "Unknown command". ....
In case LAYISO has been undefined by something, try using the period/decimal prefix [with or without the underscore, too] to force it to use the native command definition:  .LAYISO or _.LAYISO.
If you can't get it to work, try my LayerIsolateOnOff.lsp routine, with its LIO and LUO commands, available here.  There are several improvements over AutoCAD's LAYISO and LAYUNISO [see the comments on that web page and at the top of the file].  There's also another version that does it by Freezing and Thawing the un-selected Layers, rather than turning Off and On.
Kent Cooper, AIA
Message 10 of 13
I think there is a certain bug due to a plug in program that has been attached in the ACAD. However, the problem disappear as soon as I use the Freeze Layer command. As soon as I type it, but don't actually use ит, the command Layiso is recognized and ready to use. The only thing I can't get to work now, even when I restart ACAD, is the edited aliases for LAYISO in the .pgp file.
Thanks anyway!
Message 11 of 13
wispoxy
Turn off all add-ons and extras. It should work, something is interfering.
Message 12 of 13
JJUDD_RAAE
This morning I was working to update the speed of my AutoCAD and shut off these variables. It does work.
  • Changed XLOADCTL to 0
  • Changed DEMANDLOAD to 0
However, Coincidentally, it shut off my ability to LAYISO.
After turning them back to 2 & 3 respectively, I regained my ability to LAYISO.
I have no idea what they actually do to prevent this from operating normally, but figured this might have been an a way to resolve the original posters issue.
Message 13 of 13
RobDraw
For the OP, the command was not recognized.
Rob
