Layerstates with xref layers don't apply permanent xref overrides
EliANewlines
Message 1 of 23
EliANewlines
When I apply a layerstate, it permanently changes all non-xref layers. However, the xref layers seem to be in limbo: the properties are different, but in layer properties manager there are no xref overrides shown. The reason this matters is that when I reload the xref, all the properties revert to the original xref properties.
For example, in the original xref drawing, A-BLDG is set to cyan:
In the host drawing, I apply a layerstate which changes the xref layer A-BLDG to yellow and I get this:
However, there is no "xref overrides" layer filter, as you can see.
The only way to get an xref override is to manually select the layer and change the color to yellow, which results in this:
As you can see, once I do that, I get an actual xref override. As mentioned, I need the override, otherwise the xref layer reverts to the original color when I reload.
My layer settings are as follows:
VISRETAIN = 1
VISRETAINMODE = 2047
XREFOVERRIDE = 0
I understand that an easy fix would be to change VISRETAINMODE to 0, because then it won't even look at the original xref layer color. However, I want to keep VISRETAINMODE at 2047, because in general I want to sync xref properties which don't have overrides.
Any ideas?
Replies (22)
Message 21 of 23
nag_gladiator
Community Visitor
Community Visitor
i dont see this layerstate restore options in autocad for mac? can anyone help how to enable this option like any lisp file or something? thnaks.
Message 22 of 23
cadffm
board FOR MAC is the next door.
What are you refering to?
Layerproperty reste options, or restore options?
https://help.autodesk.com/view/ACDMAC/2025/ENU/?guid=GUID-A5B00FA1-97B0-45BB-B684-7BFDCD32E671
Sebastian
Message 23 of 23
pendean
Community Legend
Community Legend
AutoCAD for MAC may not have it, it is the never-spoken-about step child with missing abilities. Ask in the dedicated AUTOCAD FOR MAC forum about what you seek, here is the link @nag_gladiator https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
