Layerstates with xref layers don't apply permanent xref overrides
EliANewlines
Message 1 of 23
EliANewlines
When I apply a layerstate, it permanently changes all non-xref layers. However, the xref layers seem to be in limbo: the properties are different, but in layer properties manager there are no xref overrides shown. The reason this matters is that when I reload the xref, all the properties revert to the original xref properties.
For example, in the original xref drawing, A-BLDG is set to cyan:
In the host drawing, I apply a layerstate which changes the xref layer A-BLDG to yellow and I get this:
However, there is no "xref overrides" layer filter, as you can see.
The only way to get an xref override is to manually select the layer and change the color to yellow, which results in this:
As you can see, once I do that, I get an actual xref override. As mentioned, I need the override, otherwise the xref layer reverts to the original color when I reload.
My layer settings are as follows:
VISRETAIN = 1
VISRETAINMODE = 2047
XREFOVERRIDE = 0
I understand that an easy fix would be to change VISRETAINMODE to 0, because then it won't even look at the original xref layer color. However, I want to keep VISRETAINMODE at 2047, because in general I want to sync xref properties which don't have overrides.
Any ideas?
Replies (22)
Message 2 of 23
cadffm
on my side, it works different (restore layerstate and I get an xref layer override), in ACAD
What Product you are using {you posted in AutoCAD board, but you are using another software variant, I guess CIVIL3D?}
and what productversion? Command: ABOUT
Sebastian
Message 3 of 23
pendean
Community Legend
Community Legend
Did you create your LAYERSTATE with or without the XREF present?
Why is there a DOOR filter in one screenshot but not the others?
What significance is that since not all three match?
if you make changes to the source file (aka the 'xref'), you first have to turn off VISRETAIN in the top file, reload the XREF, then turn it back on for those layer settings to be updated in the top file. I don't quite understand how what you want is possible without it except to not change the source XREF in the first place, but do it only in the top file with the "door" filter (by recreating your layerstate to capture the XREF-named layers).
Why not use XREFOVERRIDE command (well, system variable, but you know what I mean)?
Can you also show us the LAYERSTATE command pop-up so we can see what options to selected/deselected before running your custom "layerstate" please.
Message 4 of 23
cadffm
>>"Why is there a DOOR filter in one screenshot but not the others?"
Because the first shot is from the file what is xrefs as "doors" insode another file (where both others shots came from)
>>"if you make changes to the source file (aka the 'xref'), you first have to turn off VISRETAIN in the top file, "
No, Visretainmode do the job too (but for not overriden xref layers only)
>>" XREFOVERRIDE "
? Xrefoverride changes object properties temporary, not layerproperties
Sebastian
Message 5 of 23
EliANewlines
Yes, I am using Civil 3D. I thought that because this question wasn't about civil 3d specific features, i should just post in this forum.
Message 6 of 23
cadffm
I think I found the puzzle piece you didn't mention: You are using a XREF-Layerstate in your host file, right?
The Layerstate is part of the Xref-file,
it isn't a layerstate as part of the host file.
If I use Xref-Layer states, I can reproduce it (the "wrong status" is just temporary)
if I use Layerstates from the hostfile, it works as expected.
Sebastian
Message 7 of 23
EliANewlines
I really appreciate your effort on this, thanks!
I also thought it might be due to the type of layerstate, but it isn't. I tried with all three types of layerstates - model, layout, and xref - and all three didn't produce a permanent override.
Message 8 of 23
EliANewlines
Additionally, it isn't due to any other checkboxes in the layerstate manager. This is what my manager looks like:
Message 9 of 23
cadffm
>>"I also thought it might be due to the type of layerstate, but it isn't."
>>"I tried with all three types of layerstates"
>>"- model, layout, and xref"
>>"- and all three didn't produce a permanent override."
Model and Layout should work (in mode tab, or by disable 'as vp override' option),
try it again! Restart and let's test.
Sebastian
Message 10 of 23
cadffm
You are right, but
And you posted a screenshot with 95% options hidden 😆
[F1] Layerstates
Sebastian
Message 11 of 23
EliANewlines
Model and layout "should" work, but they don't. Nothing changes if I uncheck "apply as viewport overrides".
See attached recording.
Message 12 of 23
EliANewlines
sorry about that, see image of layerstate manager with all option showing:
Message 13 of 23
pendean
Community Legend
Community Legend
That's only half the pop-up, open the other half
Message 14 of 23
cadffm
what is this!?
In door file, th elayers are in use
In hostfile, they didn't ??
Sebastian
Message 15 of 23
EliANewlines
see above
Message 16 of 23
EliANewlines
The only layer in use is "A-BLDG". I assume the reason they show as "in-use" in the original xref is because they are used in civil 3d styles or such.
Message 17 of 23
pendean
Community Legend
Community Legend
I think we are at the stage where we need access to your DWG files please.
Message 18 of 23
EliANewlines
No problem. There's nothing special in them, I created them from scratch for the purpose of this question. eTransmit is kinda overkill, so I'll leave it to you to xref "door" into "door host".
Message 19 of 23
cadffm
update
My first tests I did in 2021 (Acad), but now I was able to reproduce your issue in 2025-2022
AND 2021 too! Oh.
So there is something depending, we have to search for it.
It has nothing to do with Visretain/Visretainmode (and also not with xrefoverride)
But this time I used CIVIL3D (2025) to create this sample.. what working wrong also in my ACAD2021
hmm,
Sorry, I don't have more time for it, but I attach my other sample, what working well .
Please test it on your side with my files.
Sebastian
Message 20 of 23
EliANewlines
@cadffm
When I used your drawings, it worked fine! I was scratching my head for a few minutes, and I finally figured it out:
When the layerstate is created by using the "edit" option in layerstate manager, then it doesn't work. It only creates the fake xref overrides that don't show up in layer properties. However, when the layerstate is created by first making xref overrides then creating the layerstate (which by default takes the current layer properties), then it keeps the overrides and applies real xref overrides when it is restored.
My layerstates were made using the "edit" menu, and your layerstates were made by taking the current layer properties which already had xref overrides.
It's unfortunate that the "edit" menu is practically worthless for xrefs because of this bug, but it's something I can work with. I'll just make my layerstates the other way.
Thank you so much for your help!
