Good evening. Lately, I've been experiecing a problem in the Autocad
display. Some layers I use appears in different colors in the screen.
For exemple, when the red color in use, a dark blue in the screen,
when the yellow layer is in use, a light blue appears instead, etc.
Can you tell me how to fix this kind of problem?
Thank you.
Solved by elshawadfy. Go to Solution.
Try 3dconfig > Hardware Aceleration > off
See if it solves the problem..
Don't mention it @Anonymous ! Glad it helped..
You should update your grapics drivers regularly and check back every once in while to see if the colors look wright with acceleration on.. Autodesk also provides updates to grapics drivers for its software..
