AutoCAD Forum
layer with a different color in the screen
3 REPLIES 3
569 Views, 3 Replies
Good evening. Lately, I've been experiecing a problem in the Autocad
display. Some layers I use appears in different colors in the screen.
For exemple, when the red color in use, a dark blue in the screen,
when the yellow layer is in use, a light blue appears instead, etc.
Can you tell me how to fix this kind of problem?
Thank you.
3 REPLIES 3
elshawadfy
Try 3dconfig > Hardware Aceleration > off
See if it solves the problem..
in reply to: elshawadfy
It worked.
Thanks for your help
elshawadfy
Don't mention it @Anonymous ! Glad it helped..
You should update your grapics drivers regularly and check back every once in while to see if the colors look wright with acceleration on.. Autodesk also provides updates to grapics drivers for its software..
Forma Design Contest
