Hi ,
Layer state manager is like a snapshot of the existing layers and layer settings at the time the layer state is created . we usually use it when there is a lot of layers and different viewports.
it's NOT a must to use Layer State regardless if there is an XREF or not. layer state can be use in many cases, it's helpful command you can use it and you can ignor it.
I hope i help and Good Luck..
