layer search without opening the layer properties
leticia.campanelli
Message 1 of 9
leticia.campanelli
Hi there,
I am working for a company that has its name as a prefix to all layers, I find that it is timing consuming to scroll up and down the list every time I need to change layers.
if there wasn't a prefix I could hoover over the list and type the first letter, which works amazingly well. Is there a way to bypass the prefix?
Any suggestions are welcomed.
thanks
Replies (8)
Message 2 of 9
Valentin_CAD
@leticia.campanelli ,
Try adding an asterisk * before the layer name in the search box.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 9
leticia.campanelli
hi Emilio
In the layer properties, works fine with the *.
I am wondering in the layer pop down
Message 4 of 9
Valentin_CAD
Consider using the RENAME command and removing the Company Name (temporarily), then adding it back if needed later. See sample...
Emilio Valentin
Message 5 of 9
ВeekeeCZ
Consider using the command line to set the current layer.
Possibly this setting...
Then... just typing oran... to get...
Message 6 of 9
Kent1Cooper
[Consider explaining to the company this inefficiency of using that Layer naming standard, and maybe they'll be willing to change it.]
Kent Cooper, AIA
Message 7 of 9
ВeekeeCZ
That's a very common practice in civil engineering. We use that too.
Message 8 of 9
leticia.campanelli
Already tried that...
Message 9 of 9
Michiel.Valcke
Using layer groups can also help, the dropdown list on top will only show layers from the active group and the currently active layer. This can shorten the dropdown list significantly, so you can easily just select the layer from the list without having to search for it. I understand that will mean you sometimes have to switch groups.
