LAYER PROPERTIES - TABS ARE MISSING
RoyWickrama_RWEI
Advisor Advisor
Message 1 of 8
RoyWickrama_RWEI
After a long spell of using Autodesk Inventor, currently I am doing with AutoCAD. Getting some hard times.
I wanted to create a new layer. I did it with the help of RMB options in the dialog box.
Currently, it is showing me up a filtered list.
I would like to know how to get the layer properties tab similar to Figure-1
Please help. Thanks.
2020-07-09 17_37_58-C__Users_rwick_OneDrive_Desktop_2020-07-09 17_37_03-Layer.png - Greenshot image .png
Replies (7)
Message 2 of 8
neaton
Have you restarted and reselected your workspace? I find glitches like that usually fix themselves with a restart or reset to defaults (my last resort).
Nancy
Message 3 of 8
rkmcswain
Those are not "Tabs". Those seven buttons are, from the left:
"New Property Filter"
"New Group Filter"
"Layer States Manager"
"New Layer"
"New Layer VP Frozen in all Viewports"
"Delete layer"
"Set Current"
You are also not looking at a filtered layer list in the Figure 2, note that the layer filter is set to "All".   It sounds like you may be having a display issue, see this: https://forums.autodesk.com/t5/autocad-lt-forum/layer-properties-manager-menu-button-icons-missing/t...
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 8
RoyWickrama_RWEI
Thanks. You are right. I have no reference to know what they are: so I said tabs. I know on of them is for creating  a new layer.
Tomorrow, I am getting support from VAR on some other issue. They might fix this issue as well.
Message 5 of 8
rkmcswain
Yes, that button corresponds to this one (AutoCAD 2021 shown)
Message 6 of 8
RoyWickrama_RWEI
Thanks for the reply.
It is available in AutoCAD 2019 as well. I had another issue; i.e. the view cube was not doing well more than for the top view and the home (which was the top view).
I updated the AutoCAD installation with AutoCAD_2019.1.2_Update_64bit.exe.
Now my both problems:
1. view-cube was not functional for more than for the top-view (Figure-2)
2. Layer properties dialog box (Figure-1) are ok.
Message 7 of 8
imadHabash
if you click the house icon over the view cube , any changes ?
Good job .
Imad Habash
Message 8 of 8
RoyWickrama_RWEI
When I clicked the house icon over the view cube, it restored the top-view.
Having said sa, I was only able to do with top view. None of the other views did at all.
Note: After the upgrade, all the views are from within view-cube are functional.
