AutoCAD Forum
Layer drop down appearance
11 REPLIES 11
Message 1 of 12
peterm
1006 Views, 11 Replies
I've just installed the latest AutoCAD 2019 update and the appearance of my layer drop down has changed.
It used to match the appearance of the layer properties box like this:
But now it looks like this:
Is this correct?
11 REPLIES 11
Message 2 of 12
cadffm
in reply to: peterm
So we know that your install was not up to date, the icon changed with 2019.1.
Or do you mean the background?
Yes, it is "correct" but nothing what users wanted.
Sebastian
Message 3 of 12
peterm
in reply to: cadffm
Sorry for not being clear.
I was referring to the appearance of the icons.
Message 4 of 12
Michiel.Valcke
in reply to: peterm
Autodesk has updated most of their icons in the 2019 release for reasons stated here.
Whether it is an improvement or not, is still being debated among AutoCad users. I personally see no problem with it.
Message 5 of 12
jayhar
in reply to: peterm
I have seen similar posts in other threads on the change of the icons.
1. Turn off GRAPHICSCONFIG
2. Reset to defaults settings
3. Change Visual Style in 2d wire frame
4. Check windows Resolution
5. Update Graphic card
6. System requirements for AutoCAD 2019
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 6 of 12
peterm
in reply to: Michiel.Valcke
It just seems odd that the drop down icons don't match the dialog box icons. Why change one, but not the other?
Message 7 of 12
pendean
in reply to: peterm
FWIW the Layer DropDown icons have always looked fuzzy in 2019, the latest update did not make them any better or worse here, they remain the same and they look exactly like your screenshot.
Message 8 of 12
peterm
in reply to: pendean
I think it's that they're missing the black outline that makes them look indistinct.
Message 9 of 12
pendean
in reply to: peterm
Agreed: but a lot of other icons in the Ribbon and in the QAT (you are not using that) are also faint or fuzzy, it's a 2019 cluster-f/mess for sure.
Hope they put it all back in R2020.
Message 10 of 12
TheCADnoob
in reply to: peterm
Its in line with the broad changes in UI aesthetics. its not specific to Autodesk. Flat design really started to gain speed recently (2013) when apple went that way. Its all over the MS office suit. Different elements of the AutoCAD UI went to the Flat style at different times. The Status Bar has been in the style for a while. I personally think its the ghost of Patrick Nagel stuck in our computers (JK)
CADnoob
Message 11 of 12
peterm
in reply to: TheCADnoob
That still doesn't explain why it doesn't match the icons in the layer properties dialog. Why change one and not the other?
Message 12 of 12
Patchy
in reply to: peterm
Something for them to sell to you on the next version, otherwise nothing will improve ☺☺☺
AutoCAD Inside the Factory
