Just upgraded to 2019
john.p.addy
Message 1 of 8
john.p.addy
I have just up graded from 2017 to 2019.  Now I'm having issue with F8 for the ortho.  When I'm trying to move something left to right or up and down I usually only move, copy, stuff on the 90 degree so I keep my keep my F8 ortho on well when I do that now. I can only move left to right and right to left but I can't move up and down.  When we installed 2019 it asked if I wanted to transfer over my settings from 2017 to 2019 an I said yes.  This wasn't happening in 2017 when I installed 2019.  I also tried in using the grips which is another thing I use a lot of.
Any help would be great,  it has got me confused as why I can't move things up and down or rotate things.
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
Replies (7)
Message 2 of 8
RobDraw
Ortho works the same as it did before. It sounds like you may be in a view other than plan or your UCS has gotten messed up.
Rob
Message 3 of 8
john.p.addy
that is possible.  here is a word doc with a screenshot of what it looks like for the upper right hand corner.
Thank you,
John Addy
Message 4 of 8
john.p.addy
just noticed that, that one was 2017  I went back into 2017 to see if had change in 2017 and it did.  so now it's messed up in 2017 now also
Thank you,
John Addy
Message 5 of 8
S.Faris
Make UCS WORLD and that will do the trick. Check the VIEWCUBE it is not in TOP view, currently you are in BACK view. VIEWCUBE.png
SALMANUL FARIS
Message 6 of 8
rkmcswain
Is this only happening in a particular drawing, or in any drawing, even a new empty one?
Message 7 of 8
john.p.addy
I actually just did that with the UCS to World.   And it worked.
Thank you,
John Addy
Message 8 of 8
john.p.addy
This is the first drawing I have opened in 2019
Thank you,
John Addy
