Jumpy Cursor even with snap and grid turned off ?
hari.lallGSCRP
Message 1 of 29
hari.lallGSCRP
Hi all,
My PC recently got upgraded to following:
HP Z2 workstation running windows 10 with
i5-8600 cpu @3.10GHz
32.0 GB RAM
Nvidia Quadro P2200 graphics
I am experiencing Jumpy and erratic behavior of cursor when I have couple of xrefs in drawings. This mainly happens when I have a base map inserted as an xref and even with all the snaps and grids turned off. I have started to wonder if this processor is not good enough for the tasks i am doing? Any pointers will be much appreciated, specially if someone is running i5-8600 cpu on there workstation.
Replies (28)
Message 2 of 29
imadHabash
Q: Does this happened in every CAD dwg or just in a certain CAD file ?
just a try ... set your SELECTIONPREVIEW (System Variable) = 0 .
Imad Habash
Message 3 of 29
hari.lallGSCRP
Yes. Once I bring in the vector base map it starts acting up. Selectioncyling is turned off already as I never liked it anyway.
Message 4 of 29
vinodkl
Can you check if "3DCONFIG" is turned on?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 29
hari.lallGSCRP
Yes. I have double checked this already and turning it off doesn't make huge difference as well
Message 6 of 29
hari.lallGSCRP
Ok bit more detail on it. So it is only happening when I bring in the xref to the drawing. If I open the same xref on its own then the issue is not there. So it seems like it might be a settings related to xrefs ?
Message 7 of 29
imadHabash
would you please attache here a screenshot for this drawing ( after attaching ) ?
Imad Habash
Message 8 of 29
hari.lallGSCRP
Here it is. Base map inserted into a new drawing. Open the base map no problem and open the drawing with xref base map = Jumpy cursor. This is driving me mad at the moment.
Message 9 of 29
pendean
Community Legend
Community Legend
Post a screenshot of your ABOUT command.
AND
Post a screenshot of your GRAPHICSCONFIG command.
Also try turning off LINESMOOTHING nd LINEFADING variables.
Message 10 of 29
imadHabash
i was hope to get a global screenshot for all CAD screen NOT a partial one !!! anyway ... final request ... is it applicable to attache here your CAD dwg file with xref base map problem and the xref ( base map ) itself ?
Imad Habash
Message 11 of 29
hari.lallGSCRP
Just tried Linefading and linesmoothing to no affect.
Message 12 of 29
hari.lallGSCRP
Apologies I wasn't thinking straight. Please see the attached screen grab. Unfortunately because of copyright issues I cannot provide you with base map. Sorry
Message 13 of 29
pendean
Community Legend
Community Legend
C3D? You probably have to remove the last update you installed, see the dedicated C3D forum for similar issues to confirm, here is the link https://forums.autodesk.com/t5/civil-3d-forum/bd-p/66
Want me to ask the site admin to move your post there?
Message 14 of 29
imadHabash
just a try ... while you open your CAD dwg with attached base map
  • type  RIBBONCLOSE .
  • close your Properties dialog .
then see if any changes ?
Imad Habash
Message 15 of 29
hari.lallGSCRP
Sure, please move the post to appropriate location. I will try to uninstall the last update and report back. Sorry I was not sure where to post this as I only use Civil 3D as AutoCAD as I don't have AutoCAD on its own. Thanks for your help.
Message 16 of 29
RobDraw
More than likely, it is probably something about the XREF that is causing this. I've seen a single orphaned attribute in an XREF bring files down to a snail's pace.
Rob
Message 17 of 29
hari.lallGSCRP
How come the actual xref when opened on its own works fine?
Message 18 of 29
hari.lallGSCRP
Plus I have purged, Audited and copy pasted my xref into new drawing to be sure that nothing is messing about or left behind. Been using CAD for over 20 years and have never come across this before. I have started to believe my CPU is not good enough for the tasks I am throwing at it. Just a thought as I have tried everything.
Message 19 of 29
hari.lallGSCRP
Sorry just tried and it makes no difference. FYI - Cursor will only start acting up when start a draw line command.
Message 20 of 29
RobDraw
Sometimes these things don't become an issue until the file is XREF'd.
There are a number of things that can cause this kind of behavior. Have you tried this on another computer with a similar software setup and operating system?
Rob
