CAD Text Files to Excel
When I import CAD text file to Excel not all info comes in as it should. Block of text comes in where I tell it to but other blocks of text come in to the far right. CAD floor plans and blocks are from client. There are a bunch of <> imported to spreadsheet. Is there an easy fix? Over room name/number 1500 blocks. See attached Excel sheet.
Thanks.
Alfred.NESWADBA
Because the columns inside your text file have names, and an attribute "NAME1" of block "KA_SPACEOBJECTS" can't be saved in column A which is the attribute "NAME1" of block "KA_ROOMNAME".
As you used command _ATTEXT this command you can only get this type/structure of columns.
However, you might try a different command _DATAEXTRACTION which creates a list which might match better your needs.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
