I am trying to join two separate circular models in AutoCAD 2022. It is a circular flange and the bottom of a circular tank. I use the join command and it won't work. Any suggestions would be greatly appreciated.
Solved by Valentin-WSP. Go to Solution.
If they are solid 3D model, Have you tried UNION? - instead of join.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Thanks so much. That works.
