AutoCAD Forum
Geolocation Image quality
1 REPLY 1
E.Kaub
385 Views, 1 Reply
Is there a way to fade the aerial pictures obtained true the Geo-location tab. With normal pictures you can adjust Brightness, Contrast and Fade numbers.
Tags (1)
Labels (2)
1 REPLY 1
CodeDing
in reply to: E.Kaub
@E.Kaub ,
Yes.
1) Select the area you want to create an image of by using this capture dropdown on your Geolocation tab.
2) Then you can turn off your map, and a Geomap Image will remain. You can adjust the properties for that image.
Hope that helps.
Best,
~DD
~DD
Senior CAD Tech & AI Specialist
Need AutoLisp help? Try my custom GPT 'AutoLISP Ace':
https://chat.openai.com/g/g-Zt0xFNpOH-autolisp-ace
Technology Administrators
AutoCAD Beta
