Hello Alfred,
I do not have any network resources or settings linked into my laptops, only a wireless printer with no special settings. The printer driver is assigned by Win10 and AutoCAD 2018 and 2019 ha sit in the list as normal.
As stated previously, I startup ACAD and open a new drawing the the un-altered acad.dwt template. No apps, addins, or scripts load that were not part of the default install.
As soon as ACAD has the clean grid displayed the cursors moves smoothly and pre-selection windows generate smoothly. If I start the line command and select a start point the cursor lagged painfully unless I change to any Visual Style other than 2D Wireframe. It smoothed out for all other styles.
Although I'm sure I have been disconnected at times already, I flipped off my WiFi switch just to rule out any network related issues and Started the process over. Same effects.
I decided to reset the default profile, as I've done prior, and everything improved. This makes me confused because that was always the first thing I tried.
I went to another workstation and reset the default profile without turning off the WiFi. This didn't help, so I shut it down, turned off WiFi, rest the profile, and voila! Worked!
Why would a profile have worked differently with WiFi off? Makes me suspicious of Autodesk 360 being connected with WiFi on. I had disabled 360 in the past with no help but not sure if I reset the profile as part of that routine.
I'm calling this attempt "no 360 connection, no network, default profile reset... fixed" (2018 & 2019 resets). Still smooth after WiFi back on too!
I feel pretty good about this but will report back if it returns and I'll watch for symptoms.
Thanks for your help and the rest as well,
Blaine
Blaine Young
Senior Engineering Technician, US Army
