Issues with Page Setups/Printing in Layouts
I am trying to print a layout but although I have selected Landscape the preview under the "Printer/plotter" section is still showing the page as portrait. I have tried shutting down and restarting AutoCAD and opening different documents but I am still having the same issue.
FYI - I am using AutoCAD 2018.
Many thanks in advance.
Patchy
Go here and modify it.
s.borello
When you hit preview or plot does your drawing plot correctly? Please try it and let me know. My preview doesn't update when I toggle between portrait and landscape but my drawings print just fine.
When I look at the preview it comes up in the correct orientation but when I print the layout it comes out portrait and so chops off part of my drawing.
To expand on @Patchy's reply - here are the settings to change inside the plot driver Properties. It may save a new .pc3 file called "your printer.pc3" with the new settings, use that rather than the printer driver and it should plot landscape. I do this for my pdf creator which only makes pdfs in portrait by default.
Edit: would help if I added the screenshotprint landscape.JPG
