Issue with specifying length and moving elsewhere on drawing
jason.bowman
Message 1 of 8
jason.bowman
Another engineer in the office is having an issue in which when he copies a line and specifies a distance, it moves to a completely different part of the drawing. Its also do it when moving an object or even creating a line.
It seems as if by specifying a length, AutoCAD is recognising it as a coordinate instead?
Replies (7)
Message 2 of 8
imadHabash
HI,
would you please show us your case through screencast clip to see how really this happend?
Imad Habash
Message 3 of 8
user181
Maybe the running osanps are grabbing something. Try turning them off or specifying the osnap NONE
Message 4 of 8
DYNPICOORDS ??
Message 5 of 8
john.vellek
Hi @jason.bowman,
Does this happen on your computer too with the exact same command sequence? If not, then it is time to compare system variables. I think the DYNPICOORDS as suggested by @Anonymous is a good starting point. If you want a list of your variables there is a tool in Express Tools called SYSVDLG that should help.
Can you list the exact steps (data entry) that makes this happen? Or perhaps capture a screen or make a video that shows the issue?
John Vellek
Message 6 of 8
oswaldodcb
Hi @jason.bowman
As comrades commented it will be better if you upload a video or screencast of the problem, you can try shutting down SNAPMODE or F9.
You can also check your UCS coordinate system, maybe it's rotated or 3D,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
Message 7 of 8
john.vellek
Hi @jason.bowman,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 8 of 8
jason.bowman
We found out it was because number lock was on... That doesn't make any difference on my computer but does on my colleagues for some reason.
