System requirements for autocad
litalz
Observer Observer
litalz
Observer
Observer
hello dear autocders
my problam is this
my operating system is 32 bit
with 64 cpu
windows 10 pro ver. 1607
which autocad can I install - and where can I download a free trial?
thank you
li tal
TrainingNode-01
Hi Li
You are running the latest windows so you should be fine for AutoCAD 2016-2018.  You do however need to check your graphics card because that could be a limiting factor.  If your graphics card is not up to spec then you can use the /NOHARDWARE variable to launch the product.
You are able to download the software various ways
If you do not have an Autodesk account with the product listed or you need an older version of the software then you can use the Autodesk virtual agent.
I hope this helps
Regards
Marnus van Staden
Technical consultant & Civil 3D support Specialist
Prokon Software Consultants
Kind Regards
Marnus van Staden
N.DIP Civil Engineering | Senior Technical Specialist
Autodesk Trainer | Draughting Consultant
litalz
Observer
Observer
thank you
I will try that
Li Tal
