Issue with Adding Area - Not highlighting green
ahmadshabrawy_98
Message 1 of 14
ahmadshabrawy_98
I've been using AutoCAD 2021 on windows. when  I use the Area command -> Add -> and start to select the shape (not object or polyline), it would always turn the selected boundary green to show what is being calculated but it won't show in my version so it is very difficult to know which boundaries I already selected for adding them up.
Note: in AutoCAD 2018 it was working proprly.
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
Not doing it here: do you have the 2021.1 update installed? ABOUT command will confirm it.
In both 2018 and 2021 start OPTIONS command, go to the SEELCTION tab, then check that both PREVIEW and the VISUAL EFFECTS SETTINGS button pop-up have the same settings established.
Message 3 of 14
ahmadshabrawy_98
Thank you for your Reply.
I already done the steps you mentioned
but it still not working
I dont know whay
Message 4 of 14
pendean
Community Legend
Community Legend
No, I meant this in OPTIONS
And this is how you grab screenshots in Windows 7/8/10 instead of your method https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
Message 5 of 14
ahmadshabrawy_98
Unfortunately, the same problem exists as you see in the video.
The problem is when I press enter to select the second shape, the green highlighting of the first shape is disappeared.
Message 6 of 14
pendean
Community Legend
Community Legend
You are using the wrong command sequences.
AREA or MEASUREGEOM command, AREA option, ADD sub-option, then you click around the first area, hit <enter> once, then start clicking on the second area and so on, the green areas remain highlighted until you end this running command.
Message 7 of 14
ahmadshabrawy_98
this option is working when the areas are polyline or region, but when I have two exploded squares for example and trying to calculate their area, the green highlighting disappears when I finish the first square and press enter to add the area of the other square.
Message 8 of 14
pendean
Community Legend
Community Legend
Nope, works fine anywhere here , see before
And after
Just as I described it.
Message 9 of 14
ahmadshabrawy_98
Sorry for disturb
can you make a small video describing the way you have done it?
in the video, I have already done what you are mentioned but no way
Message 10 of 14
pendean
Community Legend
Community Legend
Start GRAPHICSCONFIG command, then turn off hardware acceleration: does that help?
I cannot repeat the example in your latest video in R2021.1 in Win10 here.
Message 11 of 14
ahmadshabrawy_98
Unfortunately no 😢
Message 12 of 14
pendean
Community Legend
Community Legend
Have you reset or reinstalled 2021 yet? Do it, but this time totally avoid migrating any content from any older version and test.
Message 13 of 14
ayush_shah00001
Community Visitor
Community Visitor
As well, I am experiencing the same issue. Previously, it worked properly, but over the past couple of days, it has been experiencing some issues and this problem has begun to occur.
Message 14 of 14
pendean
Community Legend
Community Legend
@ayush_shah00001 wrote:
...Previously, it worked properly, but over the past couple of days...
Have you had a chance to restart your PC yet?
Then RESET of your AUTOCAD may be needed https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
