Moving multiple elements into one plane
Hrvoje-
Hrvoje-
Hi!
I have 24 elements, each in its plane but parallel to the X-Y plane. Is there a command to move at once all these elements into the X-Y plane?
The file with these elements is attached to this post.
Thank you for the help!
Kind regards,
Hrvoje 🙂
GeeHaa
Sorry I don't know of an Easy way to do this but I hope this helps. Be aware I rotated them 90 degrees.  They should all be in the same plane Now. Years ago I wrote this program to bring things down to the XY plane in the world coordinate system. So I rotated them to line up with the WCS. and then set them to a Z of 0. See Attached
Kent1Cooper
That sounds like exactly what the FLATTEN Express Tool is made for.
Kent Cooper, AIA
Hrvoje-
Thank you for your help. FLATTEN tool works fine.
Kind regards,
Hrvoje 🙂
Hrvoje-
Thank you for your engagement. I see your solution works fine, but I still do not know how to do that. FLATTEN tool did it for me, so I have the solution.
Kind regards,
Hrvoje 🙂
