ISOLATE (LAYISO) HOT KEYS?????
rollins0630
rollins0630
I have used earlier versions of Auto Cad (2007) and could isolate and unisolating the control key and number keys. Is the hot keys for the 2016 Auto Cad or just the Icons in the drop down menu?
ara_neresesian
hi
You can do it by adding command on the "Command aliases"
1-press add bot.
2- in the Alias box type a for example "LL"
3-in the AutoCAD Command select "LAYISO"
4-press ok
5-press apply
and its down now by typing "LL" will have same result with icon
Vinayv4v
Hi Rollins,
Because its odd to type layi for LAYISO & layon for LAYERON.
Because the shft+number keys have no use in autocad you can assign some of them for shortcuts.
See the Screencast to Customize your keyboard shortcuts.
I use SHFT + 1 = Selectsimilar
        SHFT + 3 = Layerisolate     (didn't use 2 as we may need this key for entering @ for relative and absolute methods)
        SHFT + 4 = Layerunisolate
Here I have Shft+6 for Layerisolate & shft+7 for layerunisolate just for reference. Youu can use 2 & 3 or any number instead of this.
You can also refer the bleow link for more details regarding customization
goo.gl/YSErsf
2nd method is as metioned by Mr. Ara neresesian using the command ALIASEDIT.
Cheers,
Vinay Vijayakumaran
