Message 1 of 12
I just installed AutoCAD 2018 and was editing files that were created using AutoCAD 2016. When I save the file, I come up with the warning shown in the attached picture. This warning came up even after I changed the file format to the earlier version of .dwg (the 2018 .dwg could not be opened in earlier versions so I had to use the old 2013 .dwg file format).
So my question is, can I create/edit files in AutoCAD 2018, send them to someone using AutoCAD 2016, and still have the drawing open and continue to work as it should in the earlier version.
Thanks.
