ISO3098B.SHX not loading in AutoCAD 2017
I recently updated to AutoCAD 2017 and now every time i open a drawing it i get about 8 command messages
"Substituting [simplex.shx] for [ISO3098B.shx]."
I have saved it into my fonts folder and it is the exact same file that has worked for years and currently works on a computer with 2014.
One of the guys here had a work around for 2016 where they used isocp.shx with a different width however when i try to do this I have to change the text styles every time i open a drawing and that is just unworkable.
Does any one know how i can get either the ISO3098B to work or to get the Text Styles to change on all drawings i open?
Juergen_Becker
can you please check your support pathes in the options Dialog.
The folder where you save your shx file must be in the support pathes.
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
pendean
Community Legend
Community Legend
At the commandline in 2017 enter this exactly as shown:
(findfile "simplex.shx")
AutoCAD will tell you where that font is installed. Move all of your special fonts to that same folder. Restart AutoCAD. Your issue will go away.
