Clipped Xref Not Displaying Properly
I'm having an issue with a Xref clip where parts of the Xref outside of the inverted boundary are not displaying. See the following images.
The first image shows the Xref, which only includes the solid grey hatch, and the closed magenta polyline used to clip it.
When the clip is applied, additional triangular areas are also clipped out of the Xref.
I've had this issue in the past, in different drawings with different Xrefs that did not include hatches. I've found a work around, where if I select the Xref and drag one of the clipping vertices to anywhere else, it will alter the part of the Xref not displayed. Sometimes the wedges of of the Xref not displayed disappear completely, and sometimes I have to drag another vertex a short distance to fix it.
This is not an ideal solution though, so I was hoping someone else came across this issue in the past and has a solution or explanation as to why this occurs.
I'm running Civil3D 2017 on Windows 10, if that is helpful. The drawing and Xref are attached if anyone wants to see if they can recreate it.
Thanks for the help in advance.
